Robin Morgan
#1 Posted : Sunday, November 3, 2013 1:13:52 PM(UTC)
Robin Morgan
all four burners work but do not get red hot
#2 Posted : Monday, November 4, 2013 1:39:42 AM(UTC)
Here are your parts, includes a wiring diagram
Parts for Frigidaire FEC30C4ACD Cooktop - AppliancePartsPros.com
Check the power to/at the unit.
L1 to L2 voltage should be 240 volts.
If OK then you will have to do a live test to see if the 240 is still good when an element is on.
[COLOR="Red"]Be very careful as 240 volts is lethal.[/COLOR]
If you do not have electrical experience then I would get in a pro.
Cook top down draft vent (Oven Repair (including Ranges and Cooktops))
by Guest 1/22/2023 4:04:02 PM(UTC)
Jenn-Air Cook Top Gas Range JGC1526ADS15 (Oven Repair (including Ranges and Cooktops))
by patelvi 9/15/2021 1:11:05 PM(UTC)
kitchenAid Gas Cook top shuts off (Oven Repair (including Ranges and Cooktops))
by kkaiser343 12/6/2017 1:42:16 PM(UTC)
Jenn air gas cook top (Oven Repair (including Ranges and Cooktops))
by Mcalee45@gmail.com 4/18/2017 3:56:39 AM(UTC)
Control Panel not working/oven not working/cook top ok (Oven Repair (including Ranges and Cooktops))
by KarenWallace33458 10/20/2016 5:40:57 PM(UTC)
GE Profile gas, cook top glass #940 (Oven Repair (including Ranges and Cooktops))
by edbabcocko1@gmail.com 1/30/2016 9:12:19 AM(UTC)
GE Cook Top / Sparking from under the knob (Oven Repair (including Ranges and Cooktops))
by nj1971 7/8/2015 8:10:45 PM(UTC)
Jenn Air Cook top Low heat (Oven Repair (including Ranges and Cooktops))
by Curban 9/29/2014 12:14:42 PM(UTC)
Cook top works, but neither bake or broil work and both elements are good (Oven Repair (including Ranges and Cooktops))
by Gene Blake 5/31/2014 7:37:02 AM(UTC)
KitchenAid Electric Range Cook Top no power (Oven Repair (including Ranges and Cooktops))
by coachpelkey 4/7/2014 2:39:46 PM(UTC)
replace cook top (Oven Repair (including Ranges and Cooktops))
by brighten 9/13/2013 3:06:54 PM(UTC)
GE cook top (Oven Repair (including Ranges and Cooktops))
by SKITEXAS 4/14/2013 9:06:19 AM(UTC)
Cook top removal (Oven Repair (including Ranges and Cooktops))
by nickh 3/19/2013 5:40:22 AM(UTC)
Removing Cook Top (Oven Repair (including Ranges and Cooktops))
by Dale Paul 2/20/2013 8:20:18 AM(UTC)
glass cook top replacement (Oven Repair (including Ranges and Cooktops))
by KRAK 1/21/2013 8:07:09 PM(UTC)
