Mike7
#1 Posted : Thursday, October 24, 2013 4:48:22 AM(UTC)
Mike7
Broiler element won't work. Replaced it and still same results.
Baking element and stove top work fine.
#2 Posted : Thursday, October 24, 2013 6:04:14 AM(UTC)
Views messages in topic : 19,638
Parts for RF367LXSQ - AppliancePartsPros.com
Perhaps the thermal fuse is blown. It is Item 26 in Section 03 of the parts.
Remove power from the unit and check it with a meter, should be 0 ohms.
File Attachment(s):
RF367.pdf (129kb) downloaded 7 time(s).
Mike7
#3 Posted : Saturday, October 26, 2013 2:42:18 PM(UTC)
Mike7
Yes checked, 0 ohms. Also, doesn't the thermal fuse control the bake element as well? That is working fine.
#4 Posted : Sunday, October 27, 2013 12:06:26 AM(UTC)
No, the thermal fuse just controls the broil element.
Looking at the wiring diagram:
The bake circuit is L1 , CON2-4 , K4 relay , CON2-7 , bake element , CON4-3 , K5 relay , CON4-1 , L2
The broil circuit is L1 , CON2-4 , K3 relay , CON2-1 , bake element , thermal fuse , CON4-3 , K5 relay , CON4-1 , L2
Mike7
#5 Posted : Sunday, October 27, 2013 3:55:54 AM(UTC)
Mike7
Thank you. I'l order the fuse, replace it, and let you know the results.
#6 Posted : Sunday, October 27, 2013 6:02:00 AM(UTC)
If the fuse measures zero ohms then it is OK.
Zero ohms (dead short) not to be confused with no ohms or infinite ohms which is an open and means the fuse is blown.
Mike7
#7 Posted : Wednesday, October 30, 2013 2:41:46 PM(UTC)
Mike7
No luck with the thermal fuse replacement.
#8 Posted : Wednesday, October 30, 2013 11:03:08 PM(UTC)
Check the wiring to the broil element.
Check the broil element with a meter.
If both are OK then I would say that the control board is bad.
Mike7
#9 Posted : Thursday, October 31, 2013 4:12:48 AM(UTC)
Mike7
Thanks for all your help. I believe it is the control board. Hate it when that happens. In the last year I've replaced a washer with a bad transmission, dishwasher with a bad motor, hot water heater, Refrigerator with a bad compressor. All around 12 years old. Any thoughts on who makes quality appliances today or are we at the mercy of planned obsolescence?
Kitchen Aid Electric Range Oven YKERS208XS1 (Oven Repair (including Ranges and Cooktops))
by Steph325 3/10/2024 12:00:38 PM(UTC)
Whirlpool Electric Range Cooktop Will not Heat (Oven Repair (including Ranges and Cooktops))
by mraupie17 9/2/2023 9:50:45 AM(UTC)
Problem with Whirlpool electric range (won't heat properly anymore) (Oven Repair (including Ranges and Cooktops))
by phillydee 4/20/2023 6:10:35 AM(UTC)
Whirlpool electric range GR563LXSS (Oven Repair (including Ranges and Cooktops))
by longtimealaskan 3/6/2023 9:47:00 PM(UTC)
Samsung electric range bake and broil do not work (Oven Repair (including Ranges and Cooktops))
by Guest 12/20/2022 2:07:19 PM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Westinghouse Electric Range Model KF341R (Appliance Parts)
by GEman 5/28/2022 9:09:03 AM(UTC)
GE electric range - nothing works but the clock (Oven Repair (including Ranges and Cooktops))
by Jelltronic 5/15/2022 6:28:03 AM(UTC)
Frigidaire LGEF3043KFM Electric Range Uneven Heat (Oven Repair (including Ranges and Cooktops))
by Asweateria 2/27/2022 9:32:41 PM(UTC)
Samsung electric range (Oven Repair (including Ranges and Cooktops))
by MELLIOTT 2/8/2022 6:38:17 AM(UTC)
LG Electric Range Overheating (Oven Repair (including Ranges and Cooktops))
by jenvee 1/25/2022 7:20:52 AM(UTC)
kenmore electric range 79097459802 (Oven Repair (including Ranges and Cooktops))
by Melissadimas 1/9/2022 9:07:08 PM(UTC)
replacing latch, door on Kitchen Aid electric range series II (Oven Repair (including Ranges and Cooktops))
by WSCHUMANN 7/12/2021 6:02:36 AM(UTC)
GE Electric Range Keeps turning off (Oven Repair (including Ranges and Cooktops))
by Guest 5/7/2021 9:58:17 AM(UTC)
REPLACE OVEN DOOR OUTER GLASS FRIDGAIR ELECTRIC RANGE MODELFEF357BBA (Oven Repair (including Ranges and Cooktops))
by Guest 5/3/2021 12:14:15 PM(UTC)
