has anyone had any experience with replacing control board on 3yr old Samsung range.
The bake and broil elements test correctly for resistance.
The only thing I can see that happened is that one of the connectors burned on the broil element. It was charred and loose. I cut it off and replaced it.
The wire I used when re connecting appears to be ok, not brittle/discolored
I hate to get into the control panel replacement but it seems like that is the last thing I could try.
