slaughterj
#1 Posted : Wednesday, September 11, 2013 6:15:24 PM(UTC)
slaughterj
Ice gets made and dispenses fine into the ice container, and when the ice container is empty, the auger moves, but when ice is in the container, the auger appears to always get jammed. I have replaced the ice container and just bought from APP and replaced the auger motor. The only other apparent component in the process is the shaft that goes between the ice container and the auger motor, but that appears fine upon inspection (the dispenser door to the outside opens fine, the ice doesn't hardly get into the blades section and just appears to jam up the bottom of the ice container, with the auger lacking power to force the ice through the process). So any help in diagnosing the problem at this point would be appreciated. (Also, I checked the parts diagram in case there was some sort of further coupler between the many flanged coupler on the bottom of the ice container and the 6 sided auger shaft top, but there does not appear to be one, though that does appear to be an odd less than tight sort of connection.) Just to clarify, the auger motor is running, and the water dispenser separately is working.
slaughterj
#2 Posted : Thursday, September 12, 2013 10:27:08 AM(UTC)
slaughterj
It looks like I have the problem described here: Questions and Answers for Whirlpool 2188917 Shaft - AppliancePartsPros.com
So I am going to try out a similar solution, and see if that works.
Maytag MFI2569YEM0 - Ice not dispensing (Refrigerator & Freezer Repair)
by MinQueens 6/16/2023 5:22:06 PM(UTC)
LG Refrigerator -Ice Not Dispensing (Refrigerator & Freezer Repair)
by Guest 12/3/2021 10:36:02 AM(UTC)
GE fridge – ice not dispensing, intermittent water (Refrigerator & Freezer Repair)
by cledantec 6/21/2017 3:59:45 AM(UTC)
Ice Not Dispensing, Water Is. (Refrigerator & Freezer Repair)
by john gilliom 3/26/2013 11:43:38 AM(UTC)
Ice Not Dispensing on Door (Refrigerator & Freezer Repair)
by aggie2012 11/7/2012 11:27:21 AM(UTC)
ice not dispensing (Refrigerator & Freezer Repair)
by MLane80544 7/15/2012 3:58:34 PM(UTC)
GE - Ice not dispensing, if you try it shuts freezer off (Refrigerator & Freezer Repair)
by iowastudio 9/7/2011 11:04:29 AM(UTC)
Crushed ice not dispensing. (Refrigerator & Freezer Repair)
by hfong@imiinc.com 6/8/2011 9:05:41 PM(UTC)
GE Ice not dispensing. (Refrigerator & Freezer Repair)
by audley 4/7/2011 9:46:44 AM(UTC)
Whirlpool Ice not dispensing (Refrigerator & Freezer Repair)
by FrancisM 2/20/2011 1:27:54 PM(UTC)
by sabbith 3/18/2010 9:47:27 AM(UTC)
Refrigerator water and ice not dispensing (Refrigerator & Freezer Repair)
by craigomidyar 7/30/2008 8:47:49 AM(UTC)
