josiec
#1 Posted : Tuesday, August 20, 2013 12:38:26 PM(UTC)
josiec
dryer runs fine only if you hold the start knob
#2 Posted : Wednesday, August 21, 2013 4:04:51 AM(UTC)
Parts for GE GTDP300EM0WS Dryer - AppliancePartsPros.com
Sounds like a bad motor.
The motor has two centrifugal switches which activate when the it gets close to operating speed.
One of then closes and connects in the heating coil. This ensures that the heater does not come on before there is air flow.
The other one has two functions.
It open a set on contacts and disconnects the motor's start winding as leaving this on all the time would overheat the motor.
It also closes a set of contacts and provides a circuit path which is in parallel with the start switch. This lets you let go of the start switch and the motor continues to run. It sound like this is not working.
GE electric dryer (DCVH680EJ1MS) Stops 2 mins. Into Cycle (Dryer Repair)
by bjohns610 9/30/2019 2:15:08 AM(UTC)
GE electric dryer rotating switch (Dryer Repair)
by pamelaw72 8/21/2019 2:39:50 PM(UTC)
GE Electric Dryer Shuts Off Mid-Cycle (Dryer Repair)
by Dynocon 10/22/2015 5:20:00 PM(UTC)
GE Electric Dryer - Belt / slide fix, did I break something? (Dryer Repair)
by bmilcs 8/23/2015 1:23:57 PM(UTC)
GE electric Dryer running then had a smell and stopped (Dryer Repair)
by DDEAN 5/12/2015 7:52:33 PM(UTC)
GE Electric Dryer won't start (Dryer Repair)
by brosnan 12/13/2014 2:08:12 PM(UTC)
GE electric dryer won't heat up (Dryer Repair)
by jrogers 7/4/2013 11:55:26 AM(UTC)
GE Electric Dryer suddenly got loud (Dryer Repair)
by Newbie2 12/15/2012 6:58:35 PM(UTC)
GE Electric Dryer - Won't Start (Dryer Repair)
by stockejj 10/31/2012 8:38:36 AM(UTC)
GE Electric dryer no start (Dryer Repair)
by TravisG 4/12/2011 1:30:52 PM(UTC)
GE electric dryer wont start (Dryer Repair)
by cojay 3/13/2011 6:38:17 PM(UTC)
trouble replacing belt GE Electric Dryer (Dryer Repair)
by lshelly40 2/6/2011 11:23:33 AM(UTC)
GE Electric dryer, no heat (Dryer Repair)
by khoshkkon 11/25/2010 10:38:07 AM(UTC)
Ge Electric Dryer Start Switch (Dryer Repair)
by lwpeters52@hotmail.com 10/16/2010 2:06:48 PM(UTC)
Maytage Electric Dryer keeps shutting down (Dryer Repair)
by rwnoble 9/4/2010 7:58:49 AM(UTC)
