wmchuck
#1 Posted : Friday, August 2, 2013 6:05:13 PM(UTC)
wmchuck
The Fridge and freezer are both cooling just not all the way and there is some frost on the back wall. What should i do?
I have already made sure both fans are working properly and cleaned the coils under the fridge.
thx for any help
richappy
#2 Posted : Saturday, August 3, 2013 1:06:45 AM(UTC)
richappy
Remove the back freezer panel and describe the frost pattern. If total heavy frost, you have a defrost problem. If so, remove the control panel and turn the defrost timer till the compressor stops running. If you get no defrost action, you have a bad defrost thermostat or a bad heater.
