konst4
#1 Posted : Thursday, August 1, 2013 1:40:20 PM(UTC)
konst4
My older model LG front-loading washer was not draining all of a sudden, so I opened it up and found a small nail in the drain pump. All of the QC tests were working before I opened it up, except for the draining system, which I did manually. After putting it back together, I'm now getting a 'de' error code (door error) and none of the QC tests are working. I can hear the door lock but that's as far as it gets. I've double-checked my wires and can't figure out what I might have done wrong. Any suggestions for the 'de' error code? Trying to avoid the repair man coming out. Thanks!
HumboldtRepairMan
#2 Posted : Thursday, August 1, 2013 4:12:33 PM(UTC)
HumboldtRepairMan
DE can be door error or drain error on LG's so either something with your door circuitry is out or the door switch is acting up or the drain pump circuitry has something out. I'm suspecting you burned out your drain pump with that nail it doesn't take much. Check voltage at the drain pump in any beginning of the cycles most all washers start with a drain mode first to empty any water. Should have 120v to drain pump in the beginning if you don't then you may have a main control issue or a problem with the wire harness going to the drain pump. If you do have 120v to the drain pump then ohm out the drain pump and make sure the pump has a complete circuit if it doesn't it's burned out and needs replacement. Check your tech sheet in the bottom of the unit or on the top once you take off the top there should be paperwork taped somewhere in side unit. Good luck
konst4
#3 Posted : Thursday, August 1, 2013 5:09:25 PM(UTC)
konst4
Thanks so much - will try those things out and may come back to you with questions. Appreciate it.
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
LG washer not letting in cold water (Washer Repair)
by Cgrigson1 4/19/2024 7:34:57 AM(UTC)
** LG Washer wont spin - LE Error ** WM4070HVA (Washer Repair)
by jborka 3/14/2024 6:15:24 PM(UTC)
LG Washer WM4270HVA/01 incomplete draining OE error (Washer Repair)
by PapawZooKeeper 6/18/2023 12:46:26 PM(UTC)
LG Washer - Rotor and Stator Grinding (Washer Repair)
by Guest 11/30/2022 7:57:29 PM(UTC)
wt7600hwa lg washer (Refrigerator & Freezer Repair)
by Guest 8/19/2022 7:47:52 AM(UTC)
LG Washer Error TE (Washer Repair)
by leonthepc 7/17/2022 1:34:39 PM(UTC)
WT5270CW LG Washer (Washer Repair)
by Gerald Shaffer 7/6/2022 12:59:29 PM(UTC)
LG Washer Drain Pump Noise (Washer Repair)
by Guest 1/28/2022 8:06:10 AM(UTC)
LG washer -Drum not spinning during rinse cycle with Fe error code (Washer Repair)
by Guest 12/29/2021 3:31:30 AM(UTC)
LG washer WM2050CW has water in it after not running for a day (Washer Repair)
by hklein 12/16/2021 4:48:27 PM(UTC)
LG washer tromm (Oven Repair (including Ranges and Cooktops))
by Guest 6/18/2021 5:43:36 AM(UTC)
LG washer not powering on (Washer Repair)
by diyer2018 6/13/2021 6:29:13 PM(UTC)
lg washer power when tub is spun by hand (Washer Repair)
by robin2741 3/29/2021 10:56:54 AM(UTC)
LG Washer WT1101CW (Washer Repair)
by rsrosenberg54 3/15/2021 6:53:23 AM(UTC)
