admiralrepair
#1 Posted : Monday, July 29, 2013 11:17:07 AM(UTC)
admiralrepair
today i was washing clothes and the washer stopped working mid rinse cycle. when i would push and pull the timer knob, it made a humming sound and would start for a few seconds, but then stop. there is water in the washer, and now there is no longer any humming sound, and it doesn't work at all. is this the timer dial that went? if so, how can i replace it?
fairbank56
#2 Posted : Monday, July 29, 2013 11:59:54 AM(UTC)
fairbank56
Make sure you still have power at the outlet. Otherwise, could be the timer, lid switch or bad connection at the motor. Jump out the lid switch as per this video.
Lid switch bypassing Whirlpool direct drive washer - YouTube
If that is not the problem, remove the cabinet and check the connections at the motor. Unplug the harness connector and check for burnt/corroded connection particularly on the gray wire and the two connections on the motor thermal overload switch. If everything checks out ok, I would replace the timer.
Cabinet removal: Cabinet removing Whirlpool direct drive washer - YouTube
Timer: Whirlpool 8572976 Timer - AppliancePartsPros.com
Lid switch: Whirlpool 8318084 Lid Switch - AppliancePartsPros.com
Eric
admiralrepair
#3 Posted : Monday, July 29, 2013 12:11:47 PM(UTC)
admiralrepair
would i be able to tell if anything was wrong by opening the control panel? sometimes it does nothing. other times it hums and actually starts. the lid switch clicks on and off when i open the door. could it still be a problem?
Kenmore series 90 washer stopped working (Washer Repair)
by Guest 3/16/2024 6:19:45 AM(UTC)
Samsung Washer stopped working (Washer Repair)
by mike613 2/14/2016 9:24:39 PM(UTC)
Crosley Washer Stopped Working (Washer Repair)
by JR2015 6/22/2015 10:23:16 AM(UTC)
Stackable Washer Stopped Working (Washer Repair)
by mbpk0521 10/29/2014 9:07:41 PM(UTC)
Kitchen Aid dishwasher stopped working (Dishwasher Repair)
by acillatem 6/15/2014 6:12:42 PM(UTC)
whirlpool washer stopped working (Washer Repair)
by kenkle 8/24/2013 5:48:22 AM(UTC)
washer stopped working in middle of cycle (Washer Repair)
by kmpadilla 6/16/2013 8:09:59 AM(UTC)
Washer stopped working mid cycle ad stopped dryer (Washer Repair)
by AngelaJo81 3/20/2013 9:01:49 AM(UTC)
HotPoint dishwasher stopped working (Dishwasher Repair)
by miklik 8/30/2012 12:18:10 PM(UTC)
Whirlpool Thin Twin washer stopped working (Washer Repair)
by jenjones6775 7/9/2012 7:08:49 PM(UTC)
Frigidaire Front Load Washer stopped working (Washer Repair)
by Kipster28 6/20/2012 2:06:34 PM(UTC)
by layman 6/19/2012 5:25:18 AM(UTC)
My Maytag Washer Stopped Working (Washer Repair)
by Susinko 11/3/2011 10:30:47 PM(UTC)
Kenmore washer stopped working, then started again, making really LOUD clanging (Washer Repair)
by cazar1961 9/23/2011 9:24:44 PM(UTC)
Maytag Dishwasher Stopped Working (Dishwasher Repair)
by wdlugitch 7/3/2011 6:53:35 AM(UTC)
