Whirlpool Model GHW9150PW0: When spinning, I can hear a round metal piece (like a bee-bee) rolling around as the Metal Basket spins at bottome section of the Basket. I have opened the unit front and back but I am not able to get to the inside between the Basket and the Tub-Outer. Is there an easier way to remove this piece from such section without completely gutting it? I appreciate your help...Rudy :)
I would pull off the front panel and remove the tub to pump hose. If the tub clamp is a wire one, I would replace it with a standard adjustable band clamp. Rotate the spin basket and feal inside the tub for objects, flushing in some water may help.
