Rudy Garza
#1 Posted : Wednesday, October 7, 2009 3:43:49 PM(UTC)
Rudy Garza
Whirlpool Model GHW9150PW0: When spinning, I can hear a round metal piece (like a bee-bee) rolling around as the Metal Basket spins at bottome section of the Basket. I have opened the unit front and back but I am not able to get to the inside between the Basket and the Tub-Outer. Is there an easier way to remove this piece from such section without completely gutting it? I appreciate your help...Rudy :)
richappy
#2 Posted : Thursday, October 8, 2009 4:54:12 AM(UTC)
richappy
I would pull off the front panel and remove the tub to pump hose. If the tub clamp is a wire one, I would replace it with a standard adjustable band clamp.
Rotate the spin basket and feal inside the tub for objects, flushing in some water may help.
GE washer: loud noise when spinning (Dishwasher Repair)
by Guest 8/7/2022 12:54:21 PM(UTC)
loud noise when spinning dragging or Grinds (Washer Repair)
by mamas_kitchen 7/9/2015 4:47:30 PM(UTC)
washer makes loud noise when spinning (Washer Repair)
by billybum 3/24/2015 12:48:03 PM(UTC)
frigidaire gallery front load washer makes loud noise when spinning:( (Washer Repair)
by Tina Cox 8/23/2011 9:55:52 AM(UTC)
admiral washer making gear loud noise when spinning or aggitating? (Washer Repair)
by heidmann1 10/2/2009 11:00:57 AM(UTC)
Kenmore Elite, loud noise when spinning (Washer Repair)
by velvet911 3/15/2009 11:01:15 AM(UTC)
