AppliancePartsPros.com
Appliance Repair Help
Washer Repair
whirpool washer stopped at rinse cycle and wont drian or spin
I Did A Load Of Laundry, Put It In The Dryer Then Threw Another Load In And When I Went Downstairs To Switch Them My Washer Was Stopped On The Rinse Cycle With Water In It. I Tried All Other Settings And Cycles, But Nothing Happened.the Timer Makes A Buzzing Noise So Im Assuming Its Not That. Can Anyone Give Me An Idea Of What Could Be The Culprit?
ok i went downstairs after reading a few posts and my washer will fill up (i drained the old water out of it), but it will not spin or drain water and i dont believe this model has a belt what could it be?
Does the drive motor run or is it all quiet except for the timer buzzing? Does the timer advance or just buzz? If the motor runs but washer does not agitate, drain or spin, it's likely a bad motor coupler. If it doesn't run and makes no sound (humming?) but timer advances normally, it's likely a bad timer. If the timer does not advance, it's likely a bad lid switch.
Eric
Washer Repair
