doug1026
#1 Posted : Friday, April 19, 2013 11:57:27 AM(UTC)
doug1026
I have a GE Spacemaker microwave with a cracked door frame. I have replaced it before a number of years ago. Apparently, the heat from the range below must cause the plastic outer door frame to crack over time....not a great design.
In any case, I cannot remember how to remove the door handle, which appears to be secured with two screws -- one visible and easily accessible and the bottom one inside and not easily accessible.
Can anyone tell me how to access the bottom screw so that I can remove the old frame and install a new one?
scott5495
#2 Posted : Friday, April 19, 2013 3:45:06 PM(UTC)
scott5495
open the door. there is a plastic frame that covers the two latches. this frame
is one piece and covers the inside door frame. take a small flat screwdriver
and place between the metal and the plastic frame and carefully pry the plastic frame cover outward. the frame will pop out of the door and over the latches. you will see your two handle screws.
doug1026
#3 Posted : Saturday, April 20, 2013 2:01:47 AM(UTC)
doug1026
Thanks for your help.
Over range Microwave exhaust fan slows (Microwave Repair)
by Mmetzinger 6/3/2023 7:19:23 AM(UTC)
GE Microwave Louder and Not Heating PEB7226SF2SS (Microwave Repair)
by Guest 7/24/2022 9:39:41 AM(UTC)
Change Microwave Bulb (Microwave Repair)
by Guest 6/20/2022 7:26:07 AM(UTC)
GE Microwave Lighting Issue (Microwave Repair)
by HDL 5/5/2022 11:29:53 AM(UTC)
GE Microwave JVM1540DM4 WW - Looking for wiring diagram (Microwave Repair)
by shotgnz 10/19/2021 12:38:16 PM(UTC)
GE Microwave Not turning table nor heating JVM1540DM4WW (Microwave Repair)
by gnieciag 7/14/2021 6:33:35 PM(UTC)
GE Microwave (JE1860BH04) won't heat AND table won't turn (Microwave Repair)
by CoryH 2/17/2021 6:45:11 AM(UTC)
Samsung Over-the-Range Microwave (Microwave Repair)
by smitty121064 2/11/2021 8:14:40 AM(UTC)
GE Microwave tripping breaker (Microwave Repair)
by Bafire0731 2/21/2019 3:08:47 PM(UTC)
ge microwave door (Microwave Repair)
by david habenicht 10/29/2018 11:26:32 PM(UTC)
Samsung over range microwave no power (Microwave Repair)
by toolmaker129 10/25/2018 10:03:29 AM(UTC)
GE Microwave Not Heating (Microwave Repair)
by JIMMIEM 2/3/2018 6:14:54 AM(UTC)
GE microwave exhuast fan won't shut off (Microwave Repair)
by diy_dave54 9/21/2017 7:55:08 AM(UTC)
GE Microwave Start and Quick Start Buttons Don't Work. (Microwave Repair)
by garypatterson 5/15/2017 10:47:49 AM(UTC)
GE Microwave - dead (Microwave Repair)
by bfamily 3/5/2017 2:32:33 PM(UTC)
