Hi folks, my dryer starts to make a high pitched whining noise a few minutes after it starts. I'm thinking that it's probably the bearing??? Any advice? Thanks
Originally Posted by: Ivorytklrr Hi folks, my dryer starts to make a high pitched whining noise a few minutes after it starts. I'm thinking that it's probably the bearing??? Any advice? Thanks Ivorytklrr, You're most likely correct, it's probably is the drum bearing and shaft assembly making the noise Part number: AP2107679
Part number: AP2107609
However, the idler pulley bearing, could also make a high pitched whining noise. Part number: AP2107759
If you could isolate the noise, Is it in or near the center of the drum(drum bearing/shaft) , or is it located in the left lower rear area of the cabinet(idler assembly).
