Ivorytklrr
#1 Posted : Tuesday, April 2, 2013 9:45:22 PM(UTC)
Ivorytklrr
Hi folks, my dryer starts to make a high pitched whining noise a few minutes after it starts. I'm thinking that it's probably the bearing??? Any advice? Thanks
Joe / APP Team
#2 Posted : Wednesday, April 3, 2013 7:45:05 AM(UTC)
Joe / APP Team
Ivorytklrr, You're most likely correct, it's probably is the drum bearing and shaft assembly making the noise
Part number: AP2107679
Part number: AP2107609
However, the idler pulley bearing, could also make a high pitched whining noise.
Part number: AP2107759
If you could isolate the noise, Is it in or near the center of the drum(drum bearing/shaft) , or is it located in the left lower rear area of the cabinet(idler assembly).
