AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Washer (combo) quit working after removing dryer door
Groups: APP Team
Hi.
Check if there are numbers on the wires?
Simon.
Yep... yellow is 22, red is 32. oh yeah... I can hear the timer motor running if that makes any difference. My son also informed me that when he got the front off of the dryer that the breaker in the switch box had been tripped. So, now I'm wondering if there is a circuit board or other issue to look into... Jeez... I hate it when that happens....
I took another look... could barely see it but a white wire (#9) was loose between the timer and front cover. When I pulled it out the spade terminal had been burned. I removed the timer and found where the red 32 and yellow 22 wires connected. Replaced the terminal and hooked everything back up and it's working now.... THANKS! (sorry the images are a little blurry) From now on maybe my son will remember to unplug or turn off the breaker before tinkering with appliances where wires will be exposed.
Groups: APP Team
Congratulations on the good job.
Thank you for shearing with us your experience.
Simon.
thank you so much for your fixing info!! had the same problem and was able to fix it because of you. thank you thank you thank you!!:D
Washer Repair
