RandyJ
#1 Posted : Thursday, March 21, 2013 9:11:43 AM(UTC)
RandyJ
My son took the front off of the dryer. A blue wire was hanging loose which he reconnected to the drum (I assume it is a tub sensor wire). There are two wires (red & yellow) in the wiring bundle near the timer which were not connected and I don't see anything they may have been connected to... (see picture). When we put it all back together the washing machine filled up, door switch works, fuse checked out good... but the motor will not run. HELP!!!!
UserPostedImage
UserPostedImage
UserPostedImage
UserPostedImage
Simon / APP Team
#2 Posted : Thursday, March 21, 2013 10:12:37 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check if there are numbers on the wires?
Simon.
RandyJ
#3 Posted : Friday, March 22, 2013 2:58:47 PM(UTC)
RandyJ
Yep... yellow is 22, red is 32.
oh yeah... I can hear the timer motor running if that makes any difference. My son also informed me that when he got the front off of the dryer that the breaker in the switch box had been tripped. So, now I'm wondering if there is a circuit board or other issue to look into... Jeez... I hate it when that happens....
RandyJ
#4 Posted : Friday, March 22, 2013 3:44:53 PM(UTC)
RandyJ
I took another look... could barely see it but a white wire (#9) was loose between the timer and front cover. When I pulled it out the spade terminal had been burned. I removed the timer and found where the red 32 and yellow 22 wires connected. Replaced the terminal and hooked everything back up and it's working now.... THANKS! (sorry the images are a little blurry)
From now on maybe my son will remember to unplug or turn off the breaker before tinkering with appliances where wires will be exposed.
UserPostedImage
UserPostedImage
Simon / APP Team
#5 Posted : Friday, March 22, 2013 5:07:55 PM(UTC)
Simon / APP Team
Groups: APP Team
Congratulations on the good job.
Thank you for shearing with us your experience.
Simon.
dove_bea
#6 Posted : Thursday, December 10, 2015 2:48:25 AM(UTC)
dove_bea
thank you so much for your fixing info!! had the same problem and was able to fix it because of you. thank you thank you thank you!!:D
