heidmann1
#1 Posted : Friday, October 2, 2009 11:00:57 AM(UTC)
heidmann1
My washer hasa loud "gear mesh/bearing" type noise when spinning or aggitating? It sounds like it is coming from the transmission area. Any ideas? or common problems? Thanks
#2 Posted : Friday, October 2, 2009 2:50:41 PM(UTC)
Tilt the washer back, remove the belt and check how freely the pump pulley is moving in both directions. A faulty pump bearing is very common problem for such washers.
- The pump assembly Part number: AP4372886
heidmann1
#3 Posted : Friday, October 2, 2009 3:36:32 PM(UTC)
heidmann1
I double checked that, it is ok, i just replaced the pump last year.
#4 Posted : Friday, October 2, 2009 3:41:55 PM(UTC)
Remove the front panel and check for a water leak through the center of the tub. In such case very possible damage to the central bearing.
