AppliancePartsPros.com
Appliance Repair Help
Washer Repair
admiral washer making gear loud noise when spinning or aggitating?
My washer hasa loud "gear mesh/bearing" type noise when spinning or aggitating? It sounds like it is coming from the transmission area. Any ideas? or common problems? Thanks
Tilt the washer back, remove the belt and check how freely the pump pulley is moving in both directions. A faulty pump bearing is very common problem for such washers. - The pump assembly Part number: AP4372886
I double checked that, it is ok, i just replaced the pump last year.
Remove the front panel and check for a water leak through the center of the tub. In such case very possible damage to the central bearing.
Washer Repair
