bellaboo
#1 Posted : Thursday, October 1, 2009 1:16:49 PM(UTC)
bellaboo
Views messages in topic : 1
Dryer does not start.
Replaced thermostat & thermal fuse-was recommended.
Still does not start. I checked the push on button continuity is ok.
Timer only makes noise on low heat setting.
Could the timer be bad? Spent $42 already on non returnable parts.
Thank You
#2 Posted : Thursday, October 1, 2009 4:05:17 PM(UTC)
Replacement parts for agd4370tq0 models | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/d...0Sheet%20-%208528187.pdf
I usually do not mess with gas but this sounds like an electrical problem.
Yes but check it.
Note the thermal fuse will not stop the unit from running, it only shuts off the heat.
Put the unit into a timed dry mode.
Your circuit path is then:
Neutral , DOOR SWITCH , PUSH TO START SWITCH , MAIN and START motor windings , timer contacts BU/BK , L1 LINE
Unplug the unit and check the BU/BK contacts should be a short (0 ohms).
Remember to unplug one side of anything you are measuring. This ensures that you are not reading an alternate/parallel circuit path.
electric dryer does not start (Microwave Repair)
by RayU 12/12/2013 7:03:52 PM(UTC)
Dryer does not start (Dryer Repair)
by Kalalau 9/20/2012 12:20:37 PM(UTC)
by hibidwns 6/25/2012 1:44:16 PM(UTC)
by Bharat 1/7/2012 4:02:37 PM(UTC)
Dryer does not start, can hear motor attempting to (Dryer Repair)
by bog 11/5/2011 9:52:03 AM(UTC)
by Raymond S 8/4/2011 8:35:52 AM(UTC)
by cpboudreaux 2/15/2011 8:59:37 AM(UTC)
Dryer does not start - Amana Gas (Dryer Repair)
by timjgtr 1/8/2011 10:10:33 AM(UTC)
Dryer does not start at all (Dryer Repair)
by timjgtr 12/26/2010 2:40:08 PM(UTC)
Gae Dryer Does Not Start (Dryer Repair)
by B Wall 9/10/2010 7:03:40 AM(UTC)
by D_Druz 3/1/2010 4:41:38 PM(UTC)
Dryer does not start, makes no sound (Dryer Repair)
by Pennell 11/12/2009 5:17:16 PM(UTC)
dryer does not start (Dryer Repair)
by petecardenas 10/19/2009 8:17:02 AM(UTC)
by petecardenas 10/19/2009 8:15:29 AM(UTC)
Amana dryer does not start (Dryer Repair)
by Barjensen 8/5/2009 4:21:07 PM(UTC)
