I have a Kenmore dish washer that seem to run and work but about 10 min into its cycle the water is over flowing on to the floor. If I open the door water seems to still be flowing out of the fill spout on the left side.
If I hit cancel and drain water still flows out for a little while but the washer does drain all the water from the base.
Is there some kind of fill valve that is jamming or not sensing the cycles?
Greg
Hi Greg, Sounds like the problem is a bad water inlet valve under the dishwasher. Remove the toe panel and you'll access it. - The water inlet valve Part number: W10158389
