goingjumping
#1 Posted : Sunday, February 17, 2013 3:03:47 PM(UTC)
goingjumping
I have a Kenmore dish washer that seem to run and work but about 10 min into its cycle the water is over flowing on to the floor. If I open the door water seems to still be flowing out of the fill spout on the left side.
If I hit cancel and drain water still flows out for a little while but the washer does drain all the water from the base.
Is there some kind of fill valve that is jamming or not sensing the cycles?
Greg
#2 Posted : Monday, February 18, 2013 1:37:22 PM(UTC)
Hi Greg,
Sounds like the problem is a bad water inlet valve under the dishwasher. Remove the toe panel and you'll access it.
- The water inlet valve Part number: W10158389
