The door on my Bosch microwave rubs just a bit when I open it. If I pick up on it all is well. Is there an adjustment on the hinge to correct this? Do I have to take the outer cover off to get to it?
Thx:confused:
Hello,
I do not think there are any adjustments available. You can determine if there are any by removing the outer case.
If the microwave is less than a year old, it should be covered under the warranty.
Couldn't wait for tech any longer. After checking the assembly out, I tapped the edge of the cabinet inward, away from the bottom of the door. Everything works perfectly now. Thanks for the info.
You are welcome. I'm glad to hear you found a way around.
