I am trying to remove the back panel of the freezer so that I can thaw out the drain area which is currently frozen and causing leakage in the fridge. See pic attached. I am trying to coach my daughter how to do this over Facetime (skype). She pried off the top of it but the rest won't come off. Any ideas? Thanks. Paul:) Paul Hewgill attached the following image(s):
Hello Paul,
She has to remove the ice cube tray support on the left side.
The model number you posted is incorrect.
