Leans
#1 Posted : Thursday, February 7, 2013 4:25:32 PM(UTC)
Leans
I have a Haier AES44b. I would like to replace the start relay and overload for the compressor which is an LG ma53lbcm 115v/60Hz but I cannot find the HP rating anywhere please help!!
richappy
#2 Posted : Friday, February 8, 2013 3:00:17 AM(UTC)
richappy
You have been a member since:: 9/10/2007(UTC)
Views messages in topic : 9,586
Is the old start device a large box, or two discrete devices, an overload and small, black or brown ptc device.
Leans
#3 Posted : Friday, February 8, 2013 3:06:46 PM(UTC)
Leans
Thanks for answering. The compressor currently has a small black start relay and a small white overload. These components are separate. They are very similar to the pieces shown in these links:
http://www.********************...Relay/6748C0004D/1268268
http://www.********************...verload/265RFBYY/1206539
richappy
#4 Posted : Friday, February 8, 2013 3:18:38 PM(UTC)
richappy
Pull off the ptc start device and measure ohms between the two, round output pins, should be 5 to 10 ohms. Also, check the overload, should be about zero ohms.
If you have no meter, either get one, or have it tested.
If you cannot get the original devices, you must be carefull, selecting the wrong items, or improperly wiring them will burn out your compressor.
