Pjcibulski
#1 Posted : Tuesday, January 29, 2013 2:00:44 PM(UTC)
Pjcibulski
My oven will not longer heat - the burners, warmer, clock panel, convection turns on.
I changed the electronic contol panel and it still isn't working.
Can you please help me with reset button, is it a sensor, or wiring?
Kenmore Elite Dual Fuel Range Model 790 7938
p/n 316417312
Pam
Simon / APP Team
#2 Posted : Tuesday, January 29, 2013 3:29:36 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
There is no any fuses or hi-limit thermostats in your range.
Check if there is 240VAC to the connector block.
Check the wiring harness to the elements and control board.
Simon.
PS. The model number you provided is not complete.
Pjcibulski
#3 Posted : Wednesday, January 30, 2013 4:11:56 PM(UTC)
Pjcibulski
Simon,
Do i have fuses? Where is the connector block? Is the wiring i need to check by the control board?
MODEL 79079383401
do u think its my wiring? where is the sensor?
Pam
Simon / APP Team
#4 Posted : Thursday, January 31, 2013 10:41:37 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi, Pam.
I meant that there is no fuse inside your range.
You need to check at the wall outlet if there is 240VAC. You need to use the multimeter for that.
Remove the rear panel to check the wires going to the elements.
What did you replace? Was it the control board/clock or the control panel. If you didn't replace the control board, then most likely it 's the problem unless there is no proper voltage to the unit.
Simon.
Oven Will not heat to temp. (Oven Repair (including Ranges and Cooktops))
by rtmeek 9/12/2022 12:32:58 PM(UTC)
Frigidaire FEFL79HQA Oven Will Not Heat (Broil or Bake) (Oven Repair (including Ranges and Cooktops))
by Allen_M 5/19/2022 8:57:30 AM(UTC)
Frigidaire - Oven will not heat up but burners work (Oven Repair (including Ranges and Cooktops))
by JohnGuerra 3/18/2020 12:45:12 PM(UTC)
Frigidaire gas oven will not heat (Oven Repair (including Ranges and Cooktops))
by HHG 9/6/2019 11:33:44 AM(UTC)
GE Profile Oven will not heat past 100, broiler works (Oven Repair (including Ranges and Cooktops))
by maribernj 2/16/2016 8:37:13 AM(UTC)
Oven will not heat (Oven Repair (including Ranges and Cooktops))
by couldcareless 11/11/2015 2:05:29 PM(UTC)
by davidwhop 8/31/2014 7:17:47 AM(UTC)
Double Wall Oven will not heat up (Oven Repair (including Ranges and Cooktops))
Belarus jwmingus 11/12/2013 4:25:40 PM(UTC)
Frigidaire Left oven will not heat either element (Oven Repair (including Ranges and Cooktops))
by morang 9/27/2013 5:08:44 PM(UTC)
Thermador sc302t top oven will not heat (Oven Repair (including Ranges and Cooktops))
by bnastasi 6/9/2013 9:01:10 PM(UTC)
Lower and Upper Oven will not heat (Oven Repair (including Ranges and Cooktops))
by Igmike 4/22/2013 5:43:12 AM(UTC)
My Oven will not heat up on bake (Oven Repair (including Ranges and Cooktops))
by missy79 4/3/2013 9:59:06 AM(UTC)
Electrolux dual fuel range oven will not heat (Oven Repair (including Ranges and Cooktops))
by p.andrew 3/19/2013 8:47:44 AM(UTC)
Oven Will Not Heat (Oven Repair (including Ranges and Cooktops))
by badams1214 1/18/2013 12:14:24 PM(UTC)
Maytag Oven Will Not Heat Up (Oven Repair (including Ranges and Cooktops))
by debost 1/16/2013 9:46:49 AM(UTC)
