I have a 6-7 year old Duet dryer gew9250pw0. Sometimes (more frequently lately) the display will be off and not respond. If I wait a few minutes it will respond, turn on, and work fine. Diagnostics checked out OK.
It seems consistent that it will respond after 5-10 minutes although I've never timed it. My wife has also reported that occasionally the keypad wont respond when it is running, i had always assumed that she just had the keypad lock on or something.
Any suggestions on whether this is the control board or something else?
Thanks!
Groups: APP Team
Hi. Check all disconnect plugs at the user interface control and main control boards. Replace the UIC (user interface) first and if that is not going to help - replace the MCU (main control). Thew main control Part number: 8546219
