2 Pages12>
demgeo
#1 Posted : Friday, October 26, 2012 7:33:00 AM(UTC)
demgeo
Hello,
I am looking for some help here - out fridge is not blowing any air out of the top fridge section. I took a look at the coil under the back panel and it had froze over and had some ice build up. I unplugged the fridge, cleared the ice and pluggeg it back in - now to see if it is fixed but does anyone have any other things I can look at to resolve the following......
" Top fridge section is not cooling - do not feel any air coming from vents"
Jim
#2 Posted : Friday, October 26, 2012 5:15:01 PM(UTC)
Hi Jim,
Very likely there is some thing wrong with the defrost system in your refrigerator. The model number you posted does not come up. Verify and repost it please.
demgeo
#3 Posted : Saturday, October 27, 2012 8:54:48 AM(UTC)
demgeo
Hi Jim,
Hey there Gene,
it is a GE Profile Bottom Mount no frost fridge - I double checked and the Model # is TCX18PAABLBS Serial # is MV315540V
#4 Posted : Monday, October 29, 2012 4:03:38 PM(UTC)
Hi Jim,
I tried everything and it does not come up. Is this refrigerator made to use in US?
demgeo
#5 Posted : Monday, October 29, 2012 5:28:12 PM(UTC)
demgeo
Hi Jim,
Hey there Gene,
Up in Canada - turned out to be the thermostat.........the coils were covered with ice - repair guy didn't have one on him so I am picking one up this week and I will install it....we used a blow dryer to melt the ice and it stated cooling again so I have about a month or so to fix it....
#6 Posted : Monday, October 29, 2012 9:28:45 PM(UTC)
The new thermostat should fix it.
There is no any online technical information for non American models. That's why your model number did not come up.
Wawy
#7 Posted : Monday, December 10, 2012 10:27:23 AM(UTC)
Wawy
Same problem as Jim. Located in canada too and having a GE TCX 18 model. Want to change thermostat as per Jim's suggestion. How do I disassemble floor of refer to access thermostat / evaporator coils (please see the attached jpeg file)? Do I have to remove doors? I see 4 screws but can't seem to remove the evaporator coils cover.
Please help. Pictures would be appreciated.
Wawy
Wawy attached the following image(s):
#8 Posted : Monday, December 10, 2012 12:04:34 PM(UTC)
Hi Wawy,
Finely I found the Service manual for these refrigerators. I attached it to the post. Hope it will help.
File Attachment(s):
31-9024 - GE bottom freezer refrigerators TCX18.pdf (1,769kb) downloaded 298 time(s).
Wawy
#9 Posted : Tuesday, December 11, 2012 9:52:17 AM(UTC)
Wawy
Thanks Gene,
Much appreciated.
Wawy
#10 Posted : Tuesday, December 11, 2012 1:36:51 PM(UTC)
You are welcome Wawy. Keep us posted.
2 Pages12>
