elknuts
#1 Posted : Monday, October 8, 2012 11:08:27 AM(UTC)
elknuts
Hey guys, I am working on a frigidaire stainless side by side fridge/freezer. We have had it in storage about a year, so I brought it home and it wont freeze in the freezer side, which also makes the fridge side warm too. So here is what i have done. I dint see any oil where it was stored on the ground. I pulled the run capacitor, and it has 15 uf, i tested the starter, it has 120 volts both upper poles, i checked for a short on the compressor it was good on all three posts, also I checked resistance, and it checked ok. I can hear the compressor start and all the fans are running, but no cold. SO today I took off the back panel inside the freezer and looked around. I unplugged the wires to the defrost heater and I have 93 volts AC, I would think I would have 0, so now I am thinking that I have a heater that is staying on all the time and not letting it freeze, what voltage should I have on these two wires when not in defrost cycle? Also on this model i cant seem to find a defrost timer, is it controlled by the thermostat, or have I missed something. I am starting to see some frost on the coils inside the of the freezer on the coil, not sure if it was doing that before or not, but I have some hope. Any help would be greatly appreciated, Bruce!!
#2 Posted : Thursday, October 11, 2012 3:00:15 AM(UTC)
Parts for Frigidaire GLHS66EEB4 Refrigerator - AppliancePartsPros.com
Here is your wiring diagram
http://manuals.frigidaire.com/p...f/Anderson/240389624.pdf
[COLOR="Blue"]
I can hear the compressor start and all the fans are running, but no cold.[/COLOR]
Can you feel the compressor vibrating?
[COLOR="Blue"] SO today I took off the back panel inside the freezer and looked around. I unplugged the wires to the defrost heater and I have 93 volts AC, I would think I would have 0, so now I am thinking that I have a heater that is staying on all the time and not letting it freeze, what voltage should I have on these two wires when not in defrost cycle?[/COLOR]
The voltage should be 0 ohms. It could be just ghost voltage but 93 does seem very high for it to be this. If it was real voltage then the defrost element should have been warm/hot.
Leave it unplugged and see if the unit cools
[COLOR="Blue"] Also on this model i cant seem to find a defrost timer, is it controlled by the thermostat, or have I missed something.[/COLOR]
The defrost and the unit's temperatures are controlled by the board, see the tech sheet.
[COLOR="Blue"] I am starting to see some frost on the coils inside the of the freezer on the coil,[/COLOR]
Let it run for a while. if the coils frost over fairly evenly then your compressor/sealed system is probably OK. If you only get frost on one area usually where the freon enters the evaporator coils then you are probably low on freon.
elknuts
#3 Posted : Thursday, October 11, 2012 5:40:48 AM(UTC)
elknuts
Ok so it sounds like i probably have low freon charge, the first 6 iinches of the coil is getting frost the rest isnt. What is the best way to find a leak, I saw on ******** some freon sniffers that are supposed to find freon leaks, do they work? or is there a better way to find a leak. Any help is greatly appreciated, bruce
Kenmore (Amana) 596.79142993 Refrigerator & Freezer not getting cold enough (Refrigerator & Freezer Repair)
by Guest 8/23/2021 12:17:10 PM(UTC)
Freezer not getting cold enough to freeze water/ice cubes (Refrigerator & Freezer Repair)
by Steve_K_163 4/6/2021 4:11:28 PM(UTC)
Maytag refrigerator & freezer not getting cold (Refrigerator & Freezer Repair)
by jer1989 11/12/2016 12:10:43 PM(UTC)
Freezer Not Getting Cold Enough! (Refrigerator & Freezer Repair)
by kag716 10/4/2016 5:40:27 PM(UTC)
Freezer not getting cold enough, Fridge Fine, my use is atypical though (Refrigerator & Freezer Repair)
by jamisonia 7/14/2014 8:53:17 AM(UTC)
by varover 5/27/2014 11:30:53 AM(UTC)
Fridge & freezer not getting cold (Refrigerator & Freezer Repair)
by Mandirigma 4/26/2014 3:59:09 AM(UTC)
ge upright freezer not getting cold enough (Refrigerator & Freezer Repair)
by Wwb1969 11/26/2013 10:46:44 AM(UTC)
Upright Freezer Not Getting Cold (Refrigerator & Freezer Repair)
by R4665 10/11/2013 8:28:30 PM(UTC)
freezer not getting colder than 17 degrees (Refrigerator & Freezer Repair)
by strat1953 5/19/2013 4:10:22 PM(UTC)
Freezer Not getting cold enough (Refrigerator & Freezer Repair)
by Spanky84 12/24/2012 1:58:52 PM(UTC)
Fridge and freezer not getting cold (Refrigerator & Freezer Repair)
by DaveDaveDave1 10/3/2012 2:55:58 PM(UTC)
Fridge and freezer not getting cold. (Refrigerator & Freezer Repair)
by Dduncan18 6/26/2012 11:17:53 AM(UTC)
refrigerator/freezer not getting cold (Refrigerator & Freezer Repair)
by cj2569 5/31/2012 4:10:48 PM(UTC)
fridge & freezer not getting cold (Refrigerator & Freezer Repair)
by Ricky2012 3/15/2012 3:48:58 PM(UTC)
