baldguywithagoat
#1 Posted : 12 years ago
baldguywithagoat
I just finished installing a bearing and seal housing kit. Part# 12001561. The washer was leaking above the transmision. The washer would also ocassionally squeal between cycles, but worked pretty well. I have started a minni load for a test run, no leaks, everything is good but tub will not spin. The belt and pulleys are turning and pump is working, the aggitator also works well. Any guesses as to what I may have done wrong? The main concern I do have is the spanner wrench I ordered was to big. I installed the bearing or spanner nut hand tight then used a block of wood and hammer to tighten the last 1/4 inch to get the outer tub to line up with gasket and holes, to tight maybe. The old one seemed as tight.
Thanks,
Brian
GCFST
#2 Posted : 12 years ago
GCFST
Im no pro.... Im also waiting on answers, but since ive waited over 3 weeks with no reply Id hate to see you go through the same wait. If It USED to spin, then Id suggest taking it apart and reassembling it maybe with a little less torque?
baldguywithagoat
#3 Posted : 12 years ago
baldguywithagoat
LOL, I took your advice. The torque on the bearing made no difference, still no spin. Guess I will dump 50 more bucks on a thrust bearing, if that does not work, its off to lowes to buy a $300 Rooper so I can just chuck it when it breaks! Uncle! Good luck with your project, and thanks for the reply.
no spin cycle on regular or permanent cycles only delicate cycle (Washer Repair)
by bhartwig 9 years ago
No spin cycle on washer...need help (Washer Repair)
by 1moretoy 10 years ago
Frigidaire Stackable Lid Switch Bypass no spin cycle (Washer Repair)
by billumd 10 years ago
no spin cycle so clothes stay wet (Washer Repair)
by pmt1231 11 years ago
Maytag Atlantis No Spin Cycle Replaced Thrust Bearing. (Washer Repair)
by MarkBe 11 years ago
kenmore ~ no spin cycle (Dishwasher Repair)
by chrismo13 12 years ago
No Spin Cycle (Washer Repair)
by KJH1961 12 years ago
I replaced maytag mav6200aww brake, now no spin cycle (Washer Repair)
by jmlaudate 13 years ago
Washer tumbles but no spin cycle (Washer Repair)
by jrwhitton 13 years ago
Tumbles but no Spin Cycle (Washer Repair)
by Rob2001 13 years ago
by John Foley 13 years ago
No spin cycle or drain? Lid switch? (Washer Repair)
by 9n1Ed 13 years ago
by firefly 13 years ago
GE washer no spin cycle (Washer Repair)
by fsuglover 13 years ago
Maytag no spin cycle (Washer Repair)
by Cclcectcmc 13 years ago
