Parts for Kenmore Dryer 11096273800 - AppliancePartsPros.comI cannot find a wiring diagram for this unit. Do you have one?
If it has one odds are it is stored in the control console.
Unplug the unit and set the unit to any non timed dry mode. Now check Timer Switch 0 (TM to OR). It should be 0 ohms.
This is the contact set that sends power to the timer motor when not in timed dry.
If OK, check the resistor. It should be around 5,000 ohms. This reduces the 240 heater voltage to 120 for the timer motor. Should be connected to OR of Timer Switch 0.
Check the heater coil should be about 8 to 12 ohms. Also check that each side is infinite ohms to the frame (ground)
I am doing a bit of guessing on the above so do not take it as gospel.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
