KayHicks
#1 Posted : Tuesday, September 22, 2009 10:39:33 AM(UTC)
KayHicks
The bottom element in the oven has a bad spot on it that stays red. Turned oven off but it was still hot the next morning. Had to shut off at breaker. When turned back on the next day the oven got hot without turning it on. Could this be just the element that needs replacing or do you think it is more than that?
applianceman
#2 Posted : Tuesday, September 22, 2009 6:53:56 PM(UTC)
applianceman
If the unit is grounded out you can get heat all the time. If there is a bad place on the unit replace the unit and if it continues to heat all the time replace the control board. Appliance Repair Guide For All Major Home Appliances
Gas Oven Will Not Shut Off (Oven Repair (including Ranges and Cooktops))
by gj2001 3/1/2013 2:26:38 PM(UTC)
Oven will not shut off (Oven Repair (including Ranges and Cooktops))
by michael.visconti 8/24/2012 11:42:45 AM(UTC)
top oven will not shut off when temp is reached (Oven Repair (including Ranges and Cooktops))
by eldonmac 8/20/2012 2:24:05 PM(UTC)
by Trentkc 1/16/2011 12:18:11 PM(UTC)
Broil Element in Oven Will Not Shut Off (Oven Repair (including Ranges and Cooktops))
by stebbs 10/11/2010 7:11:42 AM(UTC)
by bborgerding 7/26/2010 1:52:26 PM(UTC)
My oven will not shut off (Oven Repair (including Ranges and Cooktops))
by brandielee28 11/27/2009 11:24:16 AM(UTC)
by michelleedwards 5/29/2009 5:23:10 AM(UTC)
Lower oven will not shut off (Oven Repair (including Ranges and Cooktops))
by Rick Stacy 4/12/2009 7:04:35 AM(UTC)
by jhoium 9/29/2007 8:51:16 AM(UTC)
