mr.merchant
#1 Posted : Thursday, August 23, 2012 9:59:01 PM(UTC)
mr.merchant
I have done a ton of research and my washer is completely apart but I still dont know what is wrong with it. The problem is it will function through all modes but wont do anything for the spin cycle. It pumps all the water out fine. The coupler is good. How do I know if the clutch is bad or if the transmition is bad. Please help!!
richappy
#2 Posted : Friday, August 24, 2012 12:45:48 AM(UTC)
richappy
Pull the pump and motor and turn the tranny coupler clockwise till the tranny engages spin. If the clutch housing fails to spin, you have a bad gear in the tranny. If hard to turn, you have bad brake shoes and a worn clutch.
You can go to my sticky above, "replacing direct drive washer brake shoes" for info.
mr.merchant
#3 Posted : Friday, August 24, 2012 3:38:03 AM(UTC)
mr.merchant
I dont know how to find your reference to more info. What is "my sticky"?
I turned the tranny coupler but it was difficult. When I look at the brake shoes and the clutch pads they seem ok, like when you look at car brake pads. They are bad even when there is pad left on them?
Are these the parts that I should get item # AP3120590 and item # AP309443. Should I get the whole Basket Drive and Brake Assembly (bit more $).
Thanks for the reply.
** LG Washer wont spin - LE Error ** WM4070HVA (Washer Repair)
by jborka 3/14/2024 6:15:24 PM(UTC)
GE Washer wont spin at the high speed GHWN4250D0WW (Washer Repair)
by ssauer40 1/10/2022 4:19:44 AM(UTC)
washer wont spin (Washer Repair)
by allen9258 4/8/2018 11:08:33 PM(UTC)
Maytag Bravos Washer wont spin (Washer Repair)
by utzzy27 10/2/2016 1:15:15 PM(UTC)
washer wont spin out (Washer Repair)
by dokratt 4/16/2016 2:50:25 PM(UTC)
Maytag Neptune washer wont spin or cycle (Washer Repair)
by Tonya 44 11/17/2015 12:56:58 PM(UTC)
ge washer wont spin or agitate (Washer Repair)
by outback32 9/29/2015 9:46:08 AM(UTC)
by Denarae 8/4/2015 7:21:30 AM(UTC)
Frigidaire Washer Wont spin high speed (Washer Repair)
by jchi2210 12/17/2014 12:01:09 PM(UTC)
washer wont spin& drain (Washer Repair)
by aristeoherrera@gmail.com 12/10/2014 3:19:57 PM(UTC)
by lvest 7/26/2014 11:09:50 AM(UTC)
by Mattbri 5/30/2014 11:16:21 AM(UTC)
ge profile washer wont spin (Washer Repair)
by ron1821 3/24/2014 4:57:26 PM(UTC)
GE profile washer wont spin (Washer Repair)
by ron1821 3/19/2014 11:31:36 AM(UTC)
Maytag washer wont spin, smoking from under and smells like burnt rubber (Washer Repair)
by trytodiy 3/13/2014 6:20:43 PM(UTC)
