ronnysharma
#1 Posted : Friday, July 27, 2012 6:51:49 PM(UTC)
ronnysharma
Hi there,
I'm having problems determining the cause for my Wine Cooler to not cool properly. When plugged in... all the fans are running. The temperature drops on the very bottom shelf of the fridge, but nowhere else. The compressor runs HOT. I put a mulit-meter on the relay switch prongs and the readings I got where 5 ohms, and 6.9 ohms. The condensor coils are clean...
Any suggestions.... I'm wondering if it's the compressor...
This is a Danby
DBC2760BLS
richappy
#2 Posted : Sunday, July 29, 2012 10:43:45 AM(UTC)
richappy
Seems like you have a bad compressor. I assume there is no evaporator fan, just a condensing fan. You can check inside the fridg for a vent and fan. If so, you might have an evaporator fan motor running backwards and not blowing any air.
ronnysharma
#3 Posted : Sunday, July 29, 2012 1:50:44 PM(UTC)
ronnysharma
There are actually 2 evaporator fans...
if you search for DG1-30, which is the compressor, you will be able to find a schematic. This is a dual climate wine cooler. I don't feel any air blowing when the fans are running... what are some possible causes for a fan to run backward, and would this be a reason for the compressor to heat up?
ronnysharma
#4 Posted : Sunday, July 29, 2012 1:52:04 PM(UTC)
ronnysharma
UserPostedImage
richappy
#5 Posted : Monday, July 30, 2012 12:21:05 AM(UTC)
richappy
The fan motors are shaded pole,induction motors. Sometimes they get poled backwards from a power surge that opens a bias winding. You will need to get to each motor and check.
refrigerator cooling problems (Refrigerator & Freezer Repair)
by san sewell 2/21/2016 12:23:32 AM(UTC)
by zhogrider 9/2/2014 2:20:49 AM(UTC)
***frigidaire Side By Side Cooling Problems (Refrigerator & Freezer Repair)
by Cheeva316 6/27/2013 6:45:34 PM(UTC)
Fridge cooling problems (Refrigerator & Freezer Repair)
by luvmyfam77 11/23/2012 12:41:17 PM(UTC)
Frigidaire side-by-side cooling problems (Refrigerator & Freezer Repair)
by ChrisTN 2/9/2012 12:28:37 PM(UTC)
GE Side by Side Bad Cooling Problems (Refrigerator & Freezer Repair)
by POKLET 7/6/2009 3:53:00 AM(UTC)
Cooling problems with Amana side-by-side (Forum Announcements)
by tsears 1/5/2009 4:34:21 PM(UTC)
