Nothing happens when you push the fan button, no beep or anything. It's over the range so very necessary.
I tried unplugging for a Long period and it didn't work.
Again model is hvm1750dm1cc. It's in cream/ bisque color.
What do you think?
If it does not beep then, most likely, the problem is a bad key pad. It comes as a part of the control panel. - The control panel Part number: WB07X11047
I think it is due to the bad wiring. [URL="http://www.**************************.com/Parts/NuTone.aspx"][/URL]
no beep. control pad. take Genes advise
