Shiningstar77
#1 Posted : Monday, June 18, 2012 12:56:21 PM(UTC)
Shiningstar77
Nothing happens when you push the fan button, no beep or anything. It's over the range so very necessary.
I tried unplugging for a Long period and it didn't work.
Again model is hvm1750dm1cc. It's in cream/ bisque color.
What do you think?
#2 Posted : Tuesday, June 19, 2012 12:52:20 PM(UTC)
If it does not beep then, most likely, the problem is a bad key pad. It comes as a part of the control panel.
- The control panel Part number: WB07X11047
matthewtin
#3 Posted : Thursday, May 16, 2013 10:21:50 PM(UTC)
matthewtin
I think it is due to the bad wiring.
[URL="http://www.**************************.com/Parts/NuTone.aspx"][/URL]
matthewtin
#4 Posted : Friday, May 17, 2013 1:31:04 AM(UTC)
matthewtin
I think it is due to the bad wiring. Check the connections again, there must be some issue in it.
____________________________________
nutone bathroom fans replacement parts
scott5495
#5 Posted : Friday, May 17, 2013 3:41:06 PM(UTC)
scott5495
no beep. control pad. take Genes advise
GH7208XRY1 exhaust fan not working (Microwave Repair)
by gjclark 5/13/2013 8:56:24 AM(UTC)
