farmerjack
#1 Posted : Monday, June 4, 2012 6:31:35 AM(UTC)
farmerjack
I have a Kenmore Elite dryer that just quit heating. I checked the thermal fuse in the fan housing and it seems okay. I also check the thermostat, thermal fuse and heating element and they all show continuity (NC circuits). What else should I check to see why it won't heat. All other functions seem normal.
thanks,
#2 Posted : Tuesday, June 5, 2012 1:44:18 AM(UTC)
Replacement parts for Kenmore 11064992300 | AppliancePartsPros.com
You mention 2 thermal fuses so I am assuming you checked the thermal fuse and the thermal cur-off.
I would check the power.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Next try the diagnostics.
If OK
Unplug the unit and swap the motor and heater relays.
I believe they are the same but double check this before swapping.
File Attachment(s):
64992300.pdf (390kb) downloaded 18 time(s).
Kenmore dryer won't heat (Dryer Repair)
by scruise 8/25/2013 8:02:47 AM(UTC)
by kypalak 1/13/2011 7:22:15 AM(UTC)
Kenmore dryer won't heat up (Dryer Repair)
by muskymike 1/15/2009 8:22:21 AM(UTC)
