willjsch
#1 Posted : Tuesday, September 1, 2009 11:22:47 AM(UTC)
willjsch
Im trying to determine what is causing a leak under the front panel of my washing machine. It only leaks when the machine is running. When off for awhile it doesnt leak. Thanks for your help in advance.
#2 Posted : Tuesday, September 1, 2009 5:02:49 PM(UTC)
Very likely the problem is a bad drain pump. You have to remove the washer cabinet to find exactly where water is coming from. The instructions are attached to the reply.
- The pump Part number: AP2907492
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LSC8244DQ0 | AppliancePartsPros.com
File Attachment(s):
How to remove the pump.doc (25kb) downloaded 17 time(s).
How to remove the washer cabinet.doc (25kb) downloaded 31 time(s).
Infusor washing machine leaks (Washer Repair)
by Clifton Hartoon 6/19/2015 8:22:15 AM(UTC)
Washing machine leaks water from rear air vent (Washer Repair)
by Lorri 3/13/2012 12:17:37 PM(UTC)
by Letty Jo 2/6/2012 12:53:05 PM(UTC)
My washing machine leaks for every load (Washer Repair)
by vballplayer30 10/18/2011 5:02:52 PM(UTC)
Washing machine leaks above Hose(tub to pump) (Washer Repair)
by rbauerpt@cox.net 5/3/2010 8:30:00 PM(UTC)
washing machine leaks during drain cycle (Washer Repair)
by atlonnett 3/16/2010 8:06:58 AM(UTC)
Washing machine leaks (Washer Repair)
by Ravenwr 3/2/2009 3:18:46 PM(UTC)
My GE washing machine leaks durring spin cycle. (Washer Repair)
by Ethan Blue 2/23/2009 8:35:20 AM(UTC)
Washing Machine Leaks From Front Tab Seal (Washer Repair)
by konekwek 12/8/2008 12:15:17 PM(UTC)
GE Washing machine leaks (Dishwasher Repair)
by Wadester 10/15/2008 10:42:36 AM(UTC)
