rbauerpt@cox.net
#1 Posted : 15 years ago
rbauerpt@cox.net
Water is coming from side of machine. between the pedastal and upper compartment.
I have removed the lower front plate. Water is coming from Hose (Tub to Pump) and now it may actually be coming from the upper attachment of the Hose. I have already order the part AP3128836. I am thinking I may also need to replace a gasket. Any suggestions?
sidfink43
#2 Posted : 15 years ago
sidfink43
I think you will find the gasket is built into the hose and you do not need a separate one. Check to make sure nothing is cracked where the hose connects.
