Charlie1076
#1 Posted : 17 years ago
Charlie1076
My Dryer was not starting....I checked the Thermal Fuse....that was the problem...no continuity...I am replacing the Thermal Fuse.....my question is do I need to change the Thermostat Part Number: AP3131939 as well?
How do I check that Part Number AP3131939 Thermostat to see if that is the problem as well. How do I check the thermostat for Continuity? Which of the four wires should I pull off from the Thermostat and where should my OHM meter be touching to check the Continuity????
When replacing the Thermal Fuse do I need to also replace the Thermostat right below it?
Please help!
abbie
#2 Posted : 17 years ago
abbie
If it,s the first time replacing the fuse all I would check would be the dryer vent. Make sure it is not plugged or kinked and that the air flow is good.
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 4 years ago
Cabrio dryer problems (Dryer Repair)
by artsalena 8 years ago
GE dryer problems (Dryer Repair)
by js072384 13 years ago
Dryer Problems (Dryer Repair)
by smartin349 13 years ago
by Mickey_951 13 years ago
by Tsailor 14 years ago
Dryer problems (Dryer Repair)
by Shoopes 15 years ago
by talbot 15 years ago
Asko condenser dryer problems (Dryer Repair)
by Marv Sumner 15 years ago
Dryer problems mikeo (Dryer Repair)
by mikeo1899 16 years ago
by berniefl 16 years ago
Dryer problems HELP (Dryer Repair)
by MizzJessica 16 years ago
by mbgrdido 16 years ago
by janezucker 16 years ago
Roper Dryer problems (Dryer Repair)
by b0001744 17 years ago
