plus5
#1 Posted : Monday, January 14, 2008 1:46:30 PM(UTC)
plus5
When I touch the oven door handle (or even walk by the range), the light flickers and it makes a "static" noise. The oven works perfectly, the door does not seem loose and the light switch is tight. Any ideas? This is more an annoyance than problem. Thanks in advance
TechnicianBrian
#2 Posted : Monday, January 14, 2008 3:22:16 PM(UTC)
TechnicianBrian
Just a thought, take the bulb lens off and see if the bulb is screwed all the way in.
plus5
#3 Posted : Monday, January 14, 2008 3:30:07 PM(UTC)
plus5
Thanks for your reply. Bulb is tight. Works normally, but flickers when door is touched, like the door is loose-but it doesn't appear to be.
TechnicianBrian
#4 Posted : Monday, January 14, 2008 6:49:05 PM(UTC)
TechnicianBrian
So much for the quick easy fix. The only parts of that circuit are the switch, the receptacle and the harness, and the switch is what actuates the lamp so I would suspect an overly sensitive switch. If the switch seems to function OK, a loose receptacle could be an issue. Open the door and vibrate the unit and see if the light flickers. If it only seems to do it when the door is closed, I would be back at the switch.
plus5
#5 Posted : Wednesday, January 16, 2008 12:39:18 PM(UTC)
plus5
Thank you so much Brian! I bet you're right, and ordered the switch.
Guest
#6 Posted : Saturday, October 9, 2021 9:46:22 AM(UTC)
Guest
Groups: Guests
Hi I have an indesit basic electric cooker the temperature light is flickering as soon as I turn it on. It just used to be on solidly until it got up to temperature where it would go off. What does this mean. Does it mean the cooker is going to break? Thank you
Guest
#7 Posted : Friday, March 4, 2022 7:56:37 PM(UTC)
Guest
Groups: Guests
When oven door is opened the light flickers what does this mean
ThatGuy
#8 Posted : Saturday, March 5, 2022 11:34:18 AM(UTC)
ThatGuy
Loose light bulb, weak light bulb socket, or door switch going bad. Have you tried a new bulb?
Guest
#9 Posted : Thursday, June 13, 2024 5:23:03 PM(UTC)
Guest
Groups: Guests
Service tech here, open the door, find the switch in the upper left or right hand corner, fiddle around with it. if the light flashes anytime you are just touching it (NOT PUSHING IT IN) it’s the switch.
oven light flickers (Oven Repair (including Ranges and Cooktops))
by ruger 2/6/2008 10:35:36 PM(UTC)
