sustanetti
#1 Posted : Tuesday, August 18, 2009 12:18:33 PM(UTC)
sustanetti
food in fridge freezing even on lowest setting.
richappy
#2 Posted : Wednesday, August 19, 2009 3:27:52 AM(UTC)
richappy
I would measure the freezer temperature, should be less than 10 degrees. If not, it's probably low on refrigerant or has a condenser clog.
sustanetti
#3 Posted : Friday, August 21, 2009 4:09:42 AM(UTC)
sustanetti
freezer is a true 10 degrees
richappy
#4 Posted : Friday, August 21, 2009 4:56:31 AM(UTC)
richappy
Clean the condenser coils in the back of fridg. and check the condensing fan. If ok, call a pro. to check it.
sustanetti
#5 Posted : Saturday, August 22, 2009 2:35:48 PM(UTC)
sustanetti
thanks richappy, i looked under fridge ann couldn't even see the coils because of the dust. blew out AND vac, did the trick. now i can finally buy groceries. fridge is only 2 years old, i would have never thought,
