dotyvb21
#1 Posted : Sunday, August 16, 2009 5:32:56 PM(UTC)
dotyvb21
Have older washer, has been working fine, but tonight it would not agitate or spin out clothes. The belt is not broke - I believe it is the motor, but then did not know if there were fuses?? anywhere. Is there a repair manual for it?
I did find the motor on line..
Thanks -
#2 Posted : Monday, August 17, 2009 4:49:41 PM(UTC)
The model number you posted does not come up and it does not look as a valid Frigidaire model number. Verify and repost it.
zenaida
#3 Posted : Monday, August 17, 2009 5:56:58 PM(UTC)
zenaida
washer does not spin .washer model is ATFB6000ESI/115VAC-60HZ-8AMPS whatis wrong with my washing machine.please help:confused:
#4 Posted : Monday, August 17, 2009 6:16:42 PM(UTC)
The first thing I would do is check the door lock/switch assembly. Remove the toe panel and look for an envelope with the tech sheet. Perform the tests as described in the tech sheet.
- The door lock/switch assembly Part number: AP3886713
Whirlpool Mod# LSQ9200KQ0 washer won't agitate or spin (Washer Repair)
by Guest 5/13/2023 11:34:56 AM(UTC)
Washer won't agitate or spin out. (Washer Repair)
by tracibailey 1/11/2019 8:43:20 AM(UTC)
Kitchen Aid Washer Won't agitate or spin (Washer Repair)
by M Yaworski 7/18/2017 7:00:37 AM(UTC)
Washer won't agitate or spin, and motor won't turn (Washer Repair)
by Jimmm59 8/24/2015 9:59:30 AM(UTC)
GE Profile Top Load Washer Won't Agitate or Spin (Washer Repair)
by keikomaru 3/21/2015 2:16:27 PM(UTC)
GE Washer Won't Agitate or Spin (Washer Repair)
by TXTerry 9/21/2014 10:35:00 AM(UTC)
GE Profile Washer Won't Agitate or Spin (Washer Repair)
by WisconsinMatt 8/19/2014 11:34:42 AM(UTC)
by patkat3 6/13/2014 8:04:56 AM(UTC)
Kenmore 90 series washer won't agitate or spin (Washer Repair)
by JayDigger 1/31/2014 9:30:29 AM(UTC)
Washer won't agitate or spin (Washer Repair)
by Jojam3000 12/17/2013 2:06:10 PM(UTC)
Frigidaire Washer Won't Agitate Or Spin (Washer Repair)
by paulem 10/7/2013 5:50:21 AM(UTC)
GE Washer Won't Agitate Or Spin (Washer Repair)
by Pat401 8/15/2013 3:01:45 PM(UTC)
by Stephenluck 6/12/2013 12:34:39 AM(UTC)
GE washer won't agitate or spin- no error codes (Washer Repair)
by Mark Falcon 5/13/2013 6:12:26 PM(UTC)
Washer won't agitate or spin, can turn motor by hand (Washer Repair)
by englaisfitz 11/14/2012 5:49:24 AM(UTC)
