Have older washer, has been working fine, but tonight it would not agitate or spin out clothes. The belt is not broke - I believe it is the motor, but then did not know if there were fuses?? anywhere. Is there a repair manual for it?
I did find the motor on line.. Thanks -
The model number you posted does not come up and it does not look as a valid Frigidaire model number. Verify and repost it.
washer does not spin .washer model is ATFB6000ESI/115VAC-60HZ-8AMPS whatis wrong with my washing machine.please help:confused:
The first thing I would do is check the door lock/switch assembly. Remove the toe panel and look for an envelope with the tech sheet. Perform the tests as described in the tech sheet. - The door lock/switch assembly Part number: AP3886713
