wajeemom
#1 Posted : Sunday, August 16, 2009 11:08:38 AM(UTC)
wajeemom
I have an AMANA dryer. The belt appears to be in correct place. Heating element working. Drum not turning. Seems to overheat.
sidfink43
#2 Posted : Tuesday, August 18, 2009 3:37:56 PM(UTC)
sidfink43
If the belt and dryn are correctly positioned the problem is the motor is not turning. The dryer is heating up because the motor is not turning the blower to exhaust the dryer.
Check to see that you have current to the motor, and if so, I suggest you change out the motor.
Good luck
Whirlpool Duet electric dryer drum not turning (Washer Repair)
by drmjtn 11/2/2014 7:52:05 AM(UTC)
GE Dryer drum not turning (Dryer Repair)
by mombert510 9/18/2013 4:02:32 AM(UTC)
Kenmore dryer drum not turning--belt is fine (Dryer Repair)
by Chrsitina White 7/23/2012 3:55:45 PM(UTC)
by blues_fan06 6/7/2012 11:48:10 AM(UTC)
Maytag dryer drum not turning (Dryer Repair)
by cflick 5/12/2011 7:47:48 AM(UTC)
