I have a 3LSC8255EQ0 side by side, Once defrosted it appear to work ok. After about a week or 2 the fridge stops cooling and the freezer follows. then ice can be seen forming on the white back panel of the freezer (this is now fridge temp.)
if i defrost if for a day, it will work again as described above. the cycle continues
what can the problem be?
Your model # is for a washer.
