thechancer2000
#1 Posted : Wednesday, August 12, 2009 12:22:30 AM(UTC)
thechancer2000
I have a 3LSC8255EQ0 side by side, Once defrosted it appear to work ok. After about a week or 2 the fridge stops cooling and the freezer follows. then ice can be seen forming on the white back panel of the freezer (this is now fridge temp.)
if i defrost if for a day, it will work again as described above. the cycle continues
what can the problem be?
richappy
#2 Posted : Wednesday, August 12, 2009 2:46:22 AM(UTC)
richappy
Your model # is for a washer.
