AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
coin op dryer timer starts but dryer doesn't turn on
Hi, Looking for suggestions. I have a coin slide operated dryer. I insert money and it turns on the timer but when you press the start button the dryer doesn't start. It had been run by a tennant non-stop for hours. Is there a cool down period? I unplugged it so the timer stopped and would cool down. Or could it be a thermostat or something else?
All comments appreciated!
We need more info. Model # ?? Gas or Electric? I's probably as simple as a thermal fuse or door switch. Please post all the info you have..:) wrench
It's an Inglis Commercial Dryer. All the stickers have fallen off it, not sure of the model. It is electric. I was thinking most likely the thermal fuse being if ran non-stop for hours and I tried to use it right after and it wouldn't start. It has been off for 24 hours and the same thing is still happening.
Remove the back panel and look for a thermal fuse. Usually a ceramic-housed type. It could be round (about 2" long) or thin about(about 1/2" wide and 2" long. May have one of these numbers on them. 3390719 or 3392519. Let me know what you find..:) wrench
Thanks, I just went with it being the Thermal fuse and replace it and all is good.
Handy little forum here.
Thanks again!
Dryer Repair
