Mike Craw
#1 Posted : Wednesday, January 9, 2008 3:05:45 PM(UTC)
Mike Craw
Hi, Looking for suggestions. I have a coin slide operated dryer. I insert money and it turns on the timer but when you press the start button the dryer doesn't start. It had been run by a tennant non-stop for hours. Is there a cool down period? I unplugged it so the timer stopped and would cool down. Or could it be a thermostat or something else?
All comments appreciated!
bentwrench1999
#2 Posted : Thursday, January 10, 2008 10:21:00 AM(UTC)
bentwrench1999
We need more info. Model # ?? Gas or Electric? I's probably as simple as a thermal fuse or door switch. Please post all the info you have..:) wrench
Mike Craw
#3 Posted : Thursday, January 10, 2008 10:45:18 AM(UTC)
Mike Craw
It's an Inglis Commercial Dryer. All the stickers have fallen off it, not sure of the model. It is electric. I was thinking most likely the thermal fuse being if ran non-stop for hours and I tried to use it right after and it wouldn't start. It has been off for 24 hours and the same thing is still happening.
bentwrench1999
#4 Posted : Thursday, January 10, 2008 11:52:26 AM(UTC)
bentwrench1999
Remove the back panel and look for a thermal fuse. Usually a ceramic-housed type. It could be round (about 2" long) or thin about(about 1/2" wide and 2" long. May have one of these numbers on them. 3390719 or 3392519. Let me know what you find..:) wrench
Mike Craw
#5 Posted : Thursday, January 10, 2008 6:26:44 PM(UTC)
Mike Craw
Thanks, I just went with it being the Thermal fuse and replace it and all is good.
Handy little forum here.
Thanks again!
