Norman Kraak
#1 Posted : Thursday, August 6, 2009 9:06:54 AM(UTC)
Norman Kraak
Oven ignites and turns off before reaching temperature:confused:
#2 Posted : Thursday, August 6, 2009 1:17:21 PM(UTC)
What exactly is difference between the set and real temperatures?
What are the complete model number, the serial number and the MFG number of the range?
Norman Kraak
#3 Posted : Thursday, August 6, 2009 3:50:14 PM(UTC)
Norman Kraak
What are the complete model number, the serial number and the Manufacturer number of the range?
Model arg 7200w Ser9710253755 amana oven never reaches set temp dont know mfg number
#4 Posted : Thursday, August 6, 2009 3:59:17 PM(UTC)
The manufacturer number is very important to find the correct part number. It should be on the name plate together with the model and serial numbers. It starts with "P11...".
Norman Kraak
#5 Posted : Friday, August 7, 2009 5:41:46 AM(UTC)
Norman Kraak
oven ignites but turns off before reaching set temp mfg number p1143329nw Amana mod arg 7200w ser 9710253755
#6 Posted : Friday, August 7, 2009 1:31:29 PM(UTC)
Norman,
Most likely the problem is a bad oven thermostat and the correction is to replace it.
- The oven thermostat Part number: AP4040869
Samsung oven temp low limit not switching back on (Oven Repair (including Ranges and Cooktops))
by amriths 2/25/2024 9:26:15 AM(UTC)
GE Cafe Dual Range - Oven Temp not matching display (Oven Repair (including Ranges and Cooktops))
by dieselgg 10/24/2023 3:22:11 PM(UTC)
Thermador wall oven temp sensor (Oven Repair (including Ranges and Cooktops))
by dxg2 6/4/2023 11:36:40 AM(UTC)
Whirlpool Oven Temperature Low (Oven Repair (including Ranges and Cooktops))
by topthumb 1/23/2023 11:37:05 AM(UTC)
Thermador oven temperature fluctuates (Oven Repair (including Ranges and Cooktops))
by tylert 7/4/2022 1:19:07 PM(UTC)
Whirlpool RBS305PDB1 wall oven temp control (Oven Repair (including Ranges and Cooktops))
by WPoven 3/28/2022 7:14:02 PM(UTC)
Oven Temperature Regulation (Oven Repair (including Ranges and Cooktops))
by Tumbleweed_2 1/27/2022 9:20:22 PM(UTC)
JDS1750FS oven not reaching oven temperarture (Oven Repair (including Ranges and Cooktops))
by Guest 11/24/2021 1:06:18 PM(UTC)
Oven temp reading fluctuations if I turn oven up in temp or off and back on.... (Oven Repair (including Ranges and Cooktops))
by lorraineg57 11/19/2020 10:44:32 AM(UTC)
Wolf Dual Fuel DF366 oven temp regulation (Oven Repair (including Ranges and Cooktops))
by illfixanything 9/7/2020 6:49:58 PM(UTC)
Whirlpool oven temp too hot (Oven Repair (including Ranges and Cooktops))
by edorrian10 10/4/2017 1:18:52 PM(UTC)
Jenn-Air dual wall oven temp sensor replacement (Oven Repair (including Ranges and Cooktops))
by jgmtfia 8/8/2017 1:20:49 AM(UTC)
Jenn-Air Oven Temperature Problems (Oven Repair (including Ranges and Cooktops))
by AndyBonner 9/3/2016 8:29:21 AM(UTC)
Whirlpool oven -long time to reach oven temp. (Oven Repair (including Ranges and Cooktops))
by Violet 1/23/2016 11:59:46 AM(UTC)
Kenmore oven temp troubleshooting (Oven Repair (including Ranges and Cooktops))
Belarus Slinger 11/28/2015 4:42:29 PM(UTC)
