Oven ignites and turns off before reaching temperature:confused:
What exactly is difference between the set and real temperatures?
What are the complete model number, the serial number and the MFG number of the range?
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) What exactly is difference between the set and real temperatures?
What are the complete model number, the serial number and the Manufacturer number of the range?
Gene. Model arg 7200w Ser9710253755 amana oven never reaches set temp dont know mfg number
The manufacturer number is very important to find the correct part number. It should be on the name plate together with the model and serial numbers. It starts with "P11...".
oven ignites but turns off before reaching set temp mfg number p1143329nw Amana mod arg 7200w ser 9710253755
Norman, Most likely the problem is a bad oven thermostat and the correction is to replace it. - The oven thermostat Part number: AP4040869
